Ir para o conteúdo principal
LG Enact Keyboard Replacement
O que você precisa
    1. LG Enact Keyboard Replacement, Battery: passo 1, imagem 1 %32 LG Enact Keyboard Replacement, Battery: passo 1, imagem 2 %32 LG Enact Keyboard Replacement, Battery: passo 1, imagem 3 %32
      • Open the back cover by prying into the bottom tab with an iFixit opening tool.
      Pergunte ao FixBot
      Comentar
    2. LG Enact Keyboard Replacement: passo 2, imagem 1 %32 LG Enact Keyboard Replacement: passo 2, imagem 2 %32 LG Enact Keyboard Replacement: passo 2, imagem 3 %32
      • Use an iFixit opening tool to remove the battery.
      Pergunte ao FixBot
      Comentar
    1. LG Enact Keyboard Replacement, Speaker: passo 3, imagem 1 %32
      • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. LG Enact Keyboard Replacement: passo 4, imagem 1 %32 LG Enact Keyboard Replacement: passo 4, imagem 2 %32
      • Use an iFixit opening pick to pop out the speaker.
      Pergunte ao FixBot
      Comentar
    1. LG Enact Keyboard Replacement, Midframe: passo 5, imagem 1 %32 LG Enact Keyboard Replacement, Midframe: passo 5, imagem 2 %32
      • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. LG Enact Keyboard Replacement: passo 6, imagem 1 %32
      • Use the iFixit opening pick to pry out the midframe.
      Pergunte ao FixBot
      Comentar
    1. LG Enact Keyboard Replacement, Motherboard: passo 7, imagem 1 %32 LG Enact Keyboard Replacement, Motherboard: passo 7, imagem 2 %32
      • Unplug the four ports connected to the motherboard.
      • Disconnect the two wires on top of the battery.
      • Disconnect the two wires under the battery.
      Pergunte ao FixBot
      Comentar
    2. LG Enact Keyboard Replacement: passo 8, imagem 1 %32 LG Enact Keyboard Replacement: passo 8, imagem 2 %32
      • Slowly pry out the motherboard using an iFixit opening pick.
      Pergunte ao FixBot
      Comentar
    1. LG Enact Keyboard Replacement, Charging Port: passo 9, imagem 1 %32 LG Enact Keyboard Replacement, Charging Port: passo 9, imagem 2 %32
      • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
      Pergunte ao FixBot
      Comentar
    1. LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 1 %32 LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 2 %32 LG Enact Keyboard Replacement, Keyboard: passo 10, imagem 3 %32
      • Gently remove the blue metal plate using an iFixit opening pick.
      • Gently remove the black plastic from inside the battery compartment.
      Pergunte ao FixBot
      Comentar
    2. LG Enact Keyboard Replacement: passo 11, imagem 1 %32
      • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. LG Enact Keyboard Replacement: passo 12, imagem 1 %32
      • Remove the ribbon cable from the battery compartment.
      Pergunte ao FixBot
      Comentar
    4. LG Enact Keyboard Replacement: passo 13, imagem 1 %32 LG Enact Keyboard Replacement: passo 13, imagem 2 %32 LG Enact Keyboard Replacement: passo 13, imagem 3 %32
      • Remove the plastic half containing the keyboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 351
