Ir para o conteúdo principal
LG Dare Digitizer Replacement
O que você precisa
  1. LG Dare Digitizer Replacement, Battery: passo 1, imagem 1 %32 LG Dare Digitizer Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
    Pergunte ao FixBot
    Comentar
  2. LG Dare Digitizer Replacement: passo 2, imagem 1 %32 LG Dare Digitizer Replacement: passo 2, imagem 2 %32 LG Dare Digitizer Replacement: passo 2, imagem 3 %32
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
    Pergunte ao FixBot
    Comentar
  3. LG Dare Digitizer Replacement, Logic Board: passo 3, imagem 1 %32 LG Dare Digitizer Replacement, Logic Board: passo 3, imagem 2 %32
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
    Pergunte ao FixBot
    Comentar
  4. LG Dare Digitizer Replacement: passo 4, imagem 1 %32 LG Dare Digitizer Replacement: passo 4, imagem 2 %32 LG Dare Digitizer Replacement: passo 4, imagem 3 %32
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
    Pergunte ao FixBot
    Comentar
  5. LG Dare Digitizer Replacement: passo 5, imagem 1 %32 LG Dare Digitizer Replacement: passo 5, imagem 2 %32 LG Dare Digitizer Replacement: passo 5, imagem 3 %32
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
    Pergunte ao FixBot
    Comentar
  6. LG Dare Digitizer Replacement: passo 6, imagem 1 %32
    • Disconnect the three ribbon connectors from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. LG Dare Digitizer Replacement: passo 7, imagem 1 %32 LG Dare Digitizer Replacement: passo 7, imagem 2 %32 LG Dare Digitizer Replacement: passo 7, imagem 3 %32
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
    Pergunte ao FixBot
    Comentar
  8. LG Dare Digitizer Replacement: passo 8, imagem 1 %32
    • Open the USB port cover.
    Pergunte ao FixBot
    Comentar
  9. LG Dare Digitizer Replacement: passo 9, imagem 1 %32 LG Dare Digitizer Replacement: passo 9, imagem 2 %32 LG Dare Digitizer Replacement: passo 9, imagem 3 %32
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
    Pergunte ao FixBot
    Comentar
  10. LG Dare Digitizer Replacement, Earpiece: passo 10, imagem 1 %32 LG Dare Digitizer Replacement, Earpiece: passo 10, imagem 2 %32 LG Dare Digitizer Replacement, Earpiece: passo 10, imagem 3 %32
    • Peel off the gold and green tape near the bottom of the phone.
    • Peel off the blue tape covering the speaker connector.
    • Peel off the gold tape to the left of the earpiece speaker.
    • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
    Pergunte ao FixBot
    Comentar
  11. LG Dare Digitizer Replacement: passo 11, imagem 1 %32 LG Dare Digitizer Replacement: passo 11, imagem 2 %32
    • Lift up the orange ribbon cable in the bottom left corner of the device.
    • Peel off the small piece of gold tape underneath the orange component back.
    Pergunte ao FixBot
    Comentar
  12. LG Dare Digitizer Replacement: passo 12, imagem 1 %32 LG Dare Digitizer Replacement: passo 12, imagem 2 %32
    • Undo the clips that attach the black plastic strip to the frame of the phone.
    • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
    Pergunte ao FixBot
    Comentar
  13. LG Dare Digitizer Replacement: passo 13, imagem 1 %32 LG Dare Digitizer Replacement: passo 13, imagem 2 %32
    • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
    Pergunte ao FixBot
    Comentar
  14. LG Dare Digitizer Replacement: passo 14, imagem 1 %32 LG Dare Digitizer Replacement: passo 14, imagem 2 %32
    • Rotate the phone upside down with the back facing you.
    • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
    Pergunte ao FixBot
    Comentar
  15. LG Dare Digitizer Replacement: passo 15, imagem 1 %32 LG Dare Digitizer Replacement: passo 15, imagem 2 %32 LG Dare Digitizer Replacement: passo 15, imagem 3 %32
    • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
    • Do not detach the frame yet.
    Pergunte ao FixBot
    Comentar
  16. LG Dare Digitizer Replacement: passo 16, imagem 1 %32 LG Dare Digitizer Replacement: passo 16, imagem 2 %32 LG Dare Digitizer Replacement: passo 16, imagem 3 %32
    • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
    Pergunte ao FixBot
    Comentar
  17. LG Dare Digitizer Replacement: passo 17, imagem 1 %32 LG Dare Digitizer Replacement: passo 17, imagem 2 %32
    • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
    • Remove the frame from the plastic panel.
    • The next two steps are for earpiece removal only.
    Pergunte ao FixBot
    Comentar
  18. LG Dare Digitizer Replacement: passo 18, imagem 1 %32 LG Dare Digitizer Replacement: passo 18, imagem 2 %32
    • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
    • It may be necessary to apply more force to remove the pad because it is taped to the frame.
    Pergunte ao FixBot
    Comentar
  19. LG Dare Digitizer Replacement: passo 19, imagem 1 %32 LG Dare Digitizer Replacement: passo 19, imagem 2 %32
    • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
    Pergunte ao FixBot
    Comentar
  20. LG Dare Digitizer Replacement, Screen: passo 20, imagem 1 %32 LG Dare Digitizer Replacement, Screen: passo 20, imagem 2 %32
    • Lift all four corners of the screen.
    • Being too aggressive could damage the screen.
    Pergunte ao FixBot
    Comentar
  21. LG Dare Digitizer Replacement: passo 21, imagem 1 %32 LG Dare Digitizer Replacement: passo 21, imagem 2 %32
    • Remove the screen from the digitizer.
    Pergunte ao FixBot
    Comentar
  22. LG Dare Digitizer Replacement, Digitizer: passo 22, imagem 1 %32 LG Dare Digitizer Replacement, Digitizer: passo 22, imagem 2 %32 LG Dare Digitizer Replacement, Digitizer: passo 22, imagem 3 %32
    • Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
    • Remove the digitizer carefully without breaking the connector.
    • Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
    Pergunte ao FixBot
    Comentar
  23. LG Dare Digitizer Replacement: passo 23, imagem 1 %32
    • Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
    Pergunte ao FixBot
    Comentar
Conclusão
To re-assemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Haoyan Huang
Membro desde: 01/26/12
151 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-4, Regan Winter 2012 Membro de Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 5,623
