Ir para o conteúdo principal
LG Cosmos 2 QWERTY Keyboard Replacement
O que você precisa
  1. LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, imagem 1 %32 LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, imagem 2 %32 LG Cosmos 2 QWERTY Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
    Pergunte ao FixBot
    Comentar
  2. LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, imagem 1 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, imagem 2 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 2, imagem 3 %32
    • Use the plastic opener to lift, and remove, the device battery.
    Pergunte ao FixBot
    Comentar
  3. LG Cosmos 2 QWERTY Keyboard Replacement, Rear Case: passo 3, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    Pergunte ao FixBot
    Comentar
  4. LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, imagem 1 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, imagem 2 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 4, imagem 3 %32
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    Pergunte ao FixBot
    Comentar
  5. LG Cosmos 2 QWERTY Keyboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
    Pergunte ao FixBot
    Comentar
  6. LG Cosmos 2 QWERTY Keyboard Replacement: passo 6, imagem 1 %32
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. LG Cosmos 2 QWERTY Keyboard Replacement: passo 7, imagem 1 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 7, imagem 2 %32
    • Use the plastic opener to disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. LG Cosmos 2 QWERTY Keyboard Replacement: passo 8, imagem 1 %32 LG Cosmos 2 QWERTY Keyboard Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
    Pergunte ao FixBot
    Comentar
  9. LG Cosmos 2 QWERTY Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the motherboard from the front case.
    Pergunte ao FixBot
    Comentar
  10. LG Cosmos 2 QWERTY Keyboard Replacement, QWERTY Keyboard: passo 10, imagem 1 %32
    • Flip the front case over. If the keyboard doesn't fall out, push it through the front case.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick White
Membro desde: 10/18/13
866 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 13-1, Benson Fall 2013 Membro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 831
