Ir para o conteúdo principal
LG Cosmos 2 LCD Display Replacement
O que você precisa
  1. LG Cosmos 2 LCD Display Replacement, Battery: passo 1, imagem 1 %32 LG Cosmos 2 LCD Display Replacement, Battery: passo 1, imagem 2 %32 LG Cosmos 2 LCD Display Replacement, Battery: passo 1, imagem 3 %32
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
    Pergunte ao FixBot
    Comentar
  2. LG Cosmos 2 LCD Display Replacement: passo 2, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 2, imagem 2 %32 LG Cosmos 2 LCD Display Replacement: passo 2, imagem 3 %32
    • Use the plastic opener to lift, and remove, the device battery.
    Pergunte ao FixBot
    Comentar
  3. LG Cosmos 2 LCD Display Replacement, Rear Case: passo 3, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    Pergunte ao FixBot
    Comentar
  4. LG Cosmos 2 LCD Display Replacement: passo 4, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 4, imagem 2 %32 LG Cosmos 2 LCD Display Replacement: passo 4, imagem 3 %32
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    Pergunte ao FixBot
    Comentar
  5. LG Cosmos 2 LCD Display Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
    Pergunte ao FixBot
    Comentar
  6. LG Cosmos 2 LCD Display Replacement: passo 6, imagem 1 %32
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. LG Cosmos 2 LCD Display Replacement: passo 7, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 7, imagem 2 %32
    • Use the plastic opener to disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. LG Cosmos 2 LCD Display Replacement: passo 8, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
    Pergunte ao FixBot
    Comentar
  9. LG Cosmos 2 LCD Display Replacement: passo 9, imagem 1 %32
    • Remove the motherboard from the front case.
    Pergunte ao FixBot
    Comentar
  10. LG Cosmos 2 LCD Display Replacement, Option Buttons: passo 10, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
    Pergunte ao FixBot
    Comentar
  11. LG Cosmos 2 LCD Display Replacement: passo 11, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 11, imagem 2 %32
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
    Pergunte ao FixBot
    Comentar
  12. LG Cosmos 2 LCD Display Replacement: passo 12, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
    Pergunte ao FixBot
    Comentar
  13. LG Cosmos 2 LCD Display Replacement: passo 13, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 13, imagem 2 %32
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
    Pergunte ao FixBot
    Comentar
  14. LG Cosmos 2 LCD Display Replacement: passo 14, imagem 1 %32
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
    Pergunte ao FixBot
    Comentar
  15. LG Cosmos 2 LCD Display Replacement: passo 15, imagem 1 %32
    • Detach the ribbon cable with the plastic opener.
    Pergunte ao FixBot
    Comentar
  16. LG Cosmos 2 LCD Display Replacement: passo 16, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 16, imagem 2 %32 LG Cosmos 2 LCD Display Replacement: passo 16, imagem 3 %32
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
    Pergunte ao FixBot
    Comentar
  17. LG Cosmos 2 LCD Display Replacement: passo 17, imagem 1 %32
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
    Pergunte ao FixBot
    Comentar
  18. LG Cosmos 2 LCD Display Replacement, LCD Display: passo 18, imagem 1 %32 LG Cosmos 2 LCD Display Replacement, LCD Display: passo 18, imagem 2 %32
    • Use a tool to pry open the LCD display. Remove the display and the circuit board that it's connected to.
    Pergunte ao FixBot
    Comentar
  19. LG Cosmos 2 LCD Display Replacement: passo 19, imagem 1 %32
    • Remove the plastic piece from the circuit board by unlocking the switch on the plastic piece with a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  20. LG Cosmos 2 LCD Display Replacement: passo 20, imagem 1 %32
    • Using a pair of tweezers, remove the tape.
    Pergunte ao FixBot
    Comentar
  21. LG Cosmos 2 LCD Display Replacement: passo 21, imagem 1 %32
    • Using either your finger or the plastic opener, disconnect the cable.
    Pergunte ao FixBot
    Comentar
  22. LG Cosmos 2 LCD Display Replacement: passo 22, imagem 1 %32 LG Cosmos 2 LCD Display Replacement: passo 22, imagem 2 %32
    • Pull the LCD display away from the circuit board.
    • You shouldn't feel any resistance. If you notice resistance, make sure you have completed the previous step.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nick White
Membro desde: 10/18/13
866 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 13-1, Benson Fall 2013 Membro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 46
Ao todo: 2,937
