Ir para o conteúdo principal
LG CineBeam Lens Replacement
O que você precisa
  1. LG CineBeam Lens Replacement, Bottom Plate: passo 1, imagem 1 %32
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. LG CineBeam Lens Replacement: passo 2, imagem 1 %32 LG CineBeam Lens Replacement: passo 2, imagem 2 %32 LG CineBeam Lens Replacement: passo 2, imagem 3 %32
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
    Pergunte ao FixBot
    Comentar
  3. LG CineBeam Lens Replacement, Motherboard: passo 3, imagem 1 %32 LG CineBeam Lens Replacement, Motherboard: passo 3, imagem 2 %32 LG CineBeam Lens Replacement, Motherboard: passo 3, imagem 3 %32
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
    Pergunte ao FixBot
    Comentar
  4. LG CineBeam Lens Replacement: passo 4, imagem 1 %32 LG CineBeam Lens Replacement: passo 4, imagem 2 %32
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
    Pergunte ao FixBot
    Comentar
  5. LG CineBeam Lens Replacement: passo 5, imagem 1 %32 LG CineBeam Lens Replacement: passo 5, imagem 2 %32 LG CineBeam Lens Replacement: passo 5, imagem 3 %32
    • Lift the motherboard out of the casing.
    Pergunte ao FixBot
    Comentar
  6. LG CineBeam Lens Replacement, Speaker: passo 6, imagem 1 %32 LG CineBeam Lens Replacement, Speaker: passo 6, imagem 2 %32
    • Use your fingers to lift the speaker from the casing.
    Pergunte ao FixBot
    Comentar
  7. LG CineBeam Lens Replacement, Lens: passo 7, imagem 1 %32 LG CineBeam Lens Replacement, Lens: passo 7, imagem 2 %32 LG CineBeam Lens Replacement, Lens: passo 7, imagem 3 %32
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
    Pergunte ao FixBot
    Comentar
  8. LG CineBeam Lens Replacement: passo 8, imagem 1 %32 LG CineBeam Lens Replacement: passo 8, imagem 2 %32
    • Remove the three 6 mm screws holding the lens and LCoS assembly in place using a Phillips #00 screwdriver.
    • Remove the lens and LCoS assembly from the casing.
    Pergunte ao FixBot
    Comentar
  9. LG CineBeam Lens Replacement: passo 9, imagem 1 %32 LG CineBeam Lens Replacement: passo 9, imagem 2 %32 LG CineBeam Lens Replacement: passo 9, imagem 3 %32
    • Remove the 4 mm screws using a Phillips #00 screwdriver.
    • Pull the lens assembly off of the display assembly.
    • When putting in a new lens assembly, make sure the focus knob is on the correct side.
    Pergunte ao FixBot
    Comentar
Conclusão
Abid Neron
Membro desde: 03/23/22
243 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 992
