Ir para o conteúdo principal
LG Chocolate Touch Buttons Replacement
O que você precisa
  1. LG Chocolate Touch Buttons Replacement, Battery: passo 1, imagem 1 %32 LG Chocolate Touch Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    Pergunte ao FixBot
    Comentar
  2. LG Chocolate Touch Buttons Replacement, Back Cover: passo 2, imagem 1 %32
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Chocolate Touch Buttons Replacement: passo 3, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 3, imagem 2 %32 LG Chocolate Touch Buttons Replacement: passo 3, imagem 3 %32
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    Pergunte ao FixBot
    Comentar
  4. LG Chocolate Touch Buttons Replacement, Sliding Front: passo 4, imagem 1 %32
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    Pergunte ao FixBot
    Comentar
  5. LG Chocolate Touch Buttons Replacement: passo 5, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 5, imagem 2 %32
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    Pergunte ao FixBot
    Comentar
  6. LG Chocolate Touch Buttons Replacement: passo 6, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 6, imagem 2 %32
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    Pergunte ao FixBot
    Comentar
  7. LG Chocolate Touch Buttons Replacement: passo 7, imagem 1 %32
    • Pry off the back cover from the front of the case using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  8. LG Chocolate Touch Buttons Replacement, LCD Board: passo 8, imagem 1 %32 LG Chocolate Touch Buttons Replacement, LCD Board: passo 8, imagem 2 %32 LG Chocolate Touch Buttons Replacement, LCD Board: passo 8, imagem 3 %32
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
    Pergunte ao FixBot
    Comentar
  9. LG Chocolate Touch Buttons Replacement: passo 9, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 9, imagem 2 %32
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
    Pergunte ao FixBot
    Comentar
  10. LG Chocolate Touch Buttons Replacement: passo 10, imagem 1 %32
    • Unhook the ribbon cable using that flat side of a spudger.
    Pergunte ao FixBot
    Comentar
  11. LG Chocolate Touch Buttons Replacement: passo 11, imagem 1 %32
    • Next, carefully remove the tape from the LCD board.
    Pergunte ao FixBot
    Comentar
  12. LG Chocolate Touch Buttons Replacement: passo 12, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 12, imagem 2 %32
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
    Pergunte ao FixBot
    Comentar
  13. LG Chocolate Touch Buttons Replacement, Touch Buttons: passo 13, imagem 1 %32
    • Using a flat head screwdriver, pry the plastic covering off of the back of the keypad
    Pergunte ao FixBot
    Comentar
  14. LG Chocolate Touch Buttons Replacement: passo 14, imagem 1 %32 LG Chocolate Touch Buttons Replacement: passo 14, imagem 2 %32
    • Push the keypad from behind to disconnect it from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Thomas
Membro desde: 01/18/13
91 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 19-46, Regan Winter 2013 Membro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 788
