Ir para o conteúdo principal
LG Chocolate Motherboard Replacement
O que você precisa
  1. LG Chocolate Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Chocolate Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    Pergunte ao FixBot
    Comentar
  2. LG Chocolate Motherboard Replacement, Back Cover: passo 2, imagem 1 %32
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Chocolate Motherboard Replacement: passo 3, imagem 1 %32 LG Chocolate Motherboard Replacement: passo 3, imagem 2 %32 LG Chocolate Motherboard Replacement: passo 3, imagem 3 %32
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    Pergunte ao FixBot
    Comentar
  4. LG Chocolate Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 LG Chocolate Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Carefully pry the motherboard off of the back case
    Pergunte ao FixBot
    Comentar
Conclusão
Maci Miri
Membro desde: 01/18/13
39 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-46, Regan Winter 2013 Membro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membros
Autoria de 22 guias
1Comentário do guia
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 1,188
