Ir para o conteúdo principal
LG Chocolate 3 Rear Case Replacement
O que você precisa
  1. LG Chocolate 3 Rear Case Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
    Pergunte ao FixBot
    Comentar
  2. LG Chocolate 3 Rear Case Replacement: passo 2, imagem 1 %32 LG Chocolate 3 Rear Case Replacement: passo 2, imagem 2 %32 LG Chocolate 3 Rear Case Replacement: passo 2, imagem 3 %32
    • Using your index finger lift and remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: passo 3, imagem 1 %32
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    Pergunte ao FixBot
    Comentar
  4. LG Chocolate 3 Rear Case Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    Pergunte ao FixBot
    Comentar
  5. LG Chocolate 3 Rear Case Replacement: passo 5, imagem 1 %32 LG Chocolate 3 Rear Case Replacement: passo 5, imagem 2 %32
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    Pergunte ao FixBot
    Comentar
  6. LG Chocolate 3 Rear Case Replacement: passo 6, imagem 1 %32
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    Pergunte ao FixBot
    Comentar
  7. LG Chocolate 3 Rear Case Replacement: passo 7, imagem 1 %32 LG Chocolate 3 Rear Case Replacement: passo 7, imagem 2 %32
    • Carefully remove the rear case from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 12-35, Amido Spring 2013 Membro de Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 585
