Ir para o conteúdo principal
LG CU515 Motherboard Replacement
O que você precisa
  1. LG CU515 Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG CU515 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use your thumb to press down and slide off the back cover of the phone.
    Pergunte ao FixBot
    Comentar
  2. LG CU515 Motherboard Replacement: passo 2, imagem 1 %32 LG CU515 Motherboard Replacement: passo 2, imagem 2 %32 LG CU515 Motherboard Replacement: passo 2, imagem 3 %32
    • Take out the battery by levering it out towards the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  3. LG CU515 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
    Pergunte ao FixBot
    Comentar
  4. LG CU515 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. LG CU515 Motherboard Replacement: passo 5, imagem 1 %32 LG CU515 Motherboard Replacement: passo 5, imagem 2 %32 LG CU515 Motherboard Replacement: passo 5, imagem 3 %32
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
    Pergunte ao FixBot
    Comentar
  6. LG CU515 Motherboard Replacement: passo 6, imagem 1 %32
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
    Pergunte ao FixBot
    Comentar
  7. LG CU515 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
    Pergunte ao FixBot
    Comentar
  8. LG CU515 Motherboard Replacement: passo 8, imagem 1 %32
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 21-55, Johann Spring 2013 Membro de Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 592
