Ir para o conteúdo principal
LG CF360 Motherboard Replacement
O que você precisa
  1. LG CF360 Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG CF360 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
    Pergunte ao FixBot
    Comentar
  2. LG CF360 Motherboard Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery.
    Pergunte ao FixBot
    Comentar
  3. LG CF360 Motherboard Replacement, Back Cover: passo 3, imagem 1 %32 LG CF360 Motherboard Replacement, Back Cover: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the two screw covers at the top of phone with tweezers.
    Pergunte ao FixBot
    Comentar
  4. LG CF360 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the six Phillips #000 (3mm) screws.
    Pergunte ao FixBot
    Comentar
  5. LG CF360 Motherboard Replacement: passo 5, imagem 1 %32 LG CF360 Motherboard Replacement: passo 5, imagem 2 %32 LG CF360 Motherboard Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
    Pergunte ao FixBot
    Comentar
  6. LG CF360 Motherboard Replacement: passo 6, imagem 1 %32
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
    Pergunte ao FixBot
    Comentar
  7. LG CF360 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 LG CF360 Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
    Pergunte ao FixBot
    Comentar
  8. LG CF360 Motherboard Replacement: passo 8, imagem 1 %32
    • Gently remove the blue transparent tape from the connector.
    Pergunte ao FixBot
    Comentar
  9. LG CF360 Motherboard Replacement: passo 9, imagem 1 %32
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Aaron
Membro desde: 10/15/13
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-27, Amido Fall 2013 Membro de Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 1,327
