Ir para o conteúdo principal
LG CF360 Front Speaker Replacement
O que você precisa
  1. LG CF360 Front Speaker Replacement, Battery: passo 1, imagem 1 %32 LG CF360 Front Speaker Replacement, Battery: passo 1, imagem 2 %32
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Front Speaker Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery.
  3. LG CF360 Front Speaker Replacement, Back Cover: passo 3, imagem 1 %32 LG CF360 Front Speaker Replacement, Back Cover: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Front Speaker Replacement: passo 4, imagem 1 %32
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Front Speaker Replacement: passo 5, imagem 1 %32 LG CF360 Front Speaker Replacement: passo 5, imagem 2 %32 LG CF360 Front Speaker Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Front Speaker Replacement: passo 6, imagem 1 %32
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Front Speaker Replacement, Motherboard: passo 7, imagem 1 %32 LG CF360 Front Speaker Replacement, Motherboard: passo 7, imagem 2 %32
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Front Speaker Replacement: passo 8, imagem 1 %32
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Front Speaker Replacement: passo 9, imagem 1 %32
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 Front Speaker Replacement, Front Case: passo 10, imagem 1 %32
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 Front Speaker Replacement: passo 11, imagem 1 %32
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 Front Speaker Replacement: passo 12, imagem 1 %32
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 Front Speaker Replacement: passo 13, imagem 1 %32
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 Front Speaker Replacement: passo 14, imagem 1 %32 LG CF360 Front Speaker Replacement: passo 14, imagem 2 %32
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 Front Speaker Replacement, Front Speaker: passo 15, imagem 1 %32
    • Be very careful to not damage the keypad board when using the plastic opening tool.
    • Gently pry the LCD ribbon from the left side of the front cover using the plastic opening tool.
    • One LCD ribbon is still connected to the keyboard, so do not attempt to remove it from the front cover.
  16. LG CF360 Front Speaker Replacement: passo 16, imagem 1 %32 LG CF360 Front Speaker Replacement: passo 16, imagem 2 %32
    • Use the plastic opening tool to partially lift up the keyboard from the front of the phone.
    • Slowly rotate the keyboard clockwise while pulling it to the right to disconnect the second LCD ribbon from the keyboard.
    • Remove the keyboard from the phone and set aside.
  17. LG CF360 Front Speaker Replacement: passo 17, imagem 1 %32
    • Do not attempt to completely remove the speaker from the phone at this point - it is still connected to the LCD screen.
    • Use the plastic opening tool to pry the front speaker from the phone.
  18. LG CF360 Front Speaker Replacement: passo 18, imagem 1 %32 LG CF360 Front Speaker Replacement: passo 18, imagem 2 %32
    • Use a soldering iron to desolder the lead junctions. If you have never used a soldering iron or you need a refresher, check out iFixit's soldering guide.
    • Separate the speaker from the LCD screen.
Conclusão
Annie White
Membro desde: 10/18/13
265 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-27, Amido Fall 2013 Membro de Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 43
Ao todo: 588
