Ir para o conteúdo principal
LG BP220 Power Cord Replacement
O que você precisa
  1. LG BP220 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 LG BP220 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
    Pergunte ao FixBot
    Comentar
  2. LG BP220 Power Cord Replacement: passo 2, imagem 1 %32 LG BP220 Power Cord Replacement: passo 2, imagem 2 %32 LG BP220 Power Cord Replacement: passo 2, imagem 3 %32
    • Beware of the capacitors as they may shock you when touched.
    • Detach the power supply cord from the brown logic board by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Bart Quicho
Membro desde: 01/13/15
520 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-1, Rose Winter 2015 Membro de UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 3,107
