Ir para o conteúdo principal
LG BP220 Disc Drive Replacement
O que você precisa
  1. LG BP220 Disc Drive Replacement, Disc Drive: passo 1, imagem 1 %32 LG BP220 Disc Drive Replacement, Disc Drive: passo 1, imagem 2 %32
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
    Pergunte ao FixBot
    Comentar
  2. LG BP220 Disc Drive Replacement: passo 2, imagem 1 %32
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
    Pergunte ao FixBot
    Comentar
  3. LG BP220 Disc Drive Replacement: passo 3, imagem 1 %32 LG BP220 Disc Drive Replacement: passo 3, imagem 2 %32 LG BP220 Disc Drive Replacement: passo 3, imagem 3 %32
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
    Pergunte ao FixBot
    Comentar
  4. LG BP220 Disc Drive Replacement: passo 4, imagem 1 %32 LG BP220 Disc Drive Replacement: passo 4, imagem 2 %32
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive and pull out to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Bart Quicho
Membro desde: 01/13/15
520 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-1, Rose Winter 2015 Membro de UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 77
Ao todo: 9,529
