Ir para o conteúdo principal
LG Ally VS740 Screen Replacement
O que você precisa
  1. LG Ally VS740 Screen Replacement, Screen Replacement: passo 1, imagem 1 %32
    • Remove Battery
    • Remove all 6 screws that are on the outer edge of phone
    Pergunte ao FixBot
    Comentar
  2. LG Ally VS740 Screen Replacement: passo 2, imagem 1 %32 LG Ally VS740 Screen Replacement: passo 2, imagem 2 %32
    • Remove backcasing connected to the rest of the phone.
    • Remove the phillip screw from the small white box on the top left corner that’s on the battery platform of the phone.
    Pergunte ao FixBot
    Comentar
  3. LG Ally VS740 Screen Replacement: passo 3, imagem 1 %32 LG Ally VS740 Screen Replacement: passo 3, imagem 2 %32
    • Remove phone sticker and remove screw under the sticker. Now you can remove the motherboard. Be careful with the tether still connected to it.
    • Remove tether.
    Pergunte ao FixBot
    Comentar
  4. LG Ally VS740 Screen Replacement: passo 4, imagem 1 %32
    • Remove the keyboard, and the rubber caps behind the phone.
    • To the right hand side of where the keyboard was, remove the four screws shown.
    Pergunte ao FixBot
    Comentar
  5. LG Ally VS740 Screen Replacement: passo 5, imagem 1 %32
    • Release clips with prying tool and take off the next layer of the phone.
    Pergunte ao FixBot
    Comentar
    • Release the pop-connectors, and the flex cable at the top by the speaker.
    • . Now you can easily remove the yellow cabling on the phone.
    Pergunte ao FixBot
    Comentar
    • Release jaw connector. Now remove LCD screen. You can now replace the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Billy Carias
Membro desde: 10/23/14
219 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 1,241
