Ir para o conteúdo principal
LG 305C Battery Replacement
O que você precisa
  1. LG 305C Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
    Pergunte ao FixBot
    Comentar
  2. LG 305C Battery Replacement: passo 2, imagem 1 %32
    • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team S6-G1, Baechle Spring 2018 Membro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 467
