Ir para o conteúdo principal
LG 305C Touch Screen Assembly Replacement
O que você precisa
  1. LG 305C  Touch Screen Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C  Touch Screen Assembly Replacement: passo 2, imagem 1 %32
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C  Touch Screen Assembly Replacement, Touch Screen: passo 3, imagem 1 %32 LG 305C  Touch Screen Assembly Replacement, Touch Screen: passo 3, imagem 2 %32
    • Here you can identify your device by reading the Model number which should read LG 305C.
    • Having done this you can be sure your device is an LG 305C and we can continue onto replacing the screen.
  4. LG 305C  Touch Screen Assembly Replacement, SD Card Removal: passo 4, imagem 1 %32
  5. LG 305C  Touch Screen Assembly Replacement: passo 5, imagem 1 %32 LG 305C  Touch Screen Assembly Replacement: passo 5, imagem 2 %32 LG 305C  Touch Screen Assembly Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the seven screws that are located along the edges of the device.
  6. LG 305C  Touch Screen Assembly Replacement: passo 6, imagem 1 %32 LG 305C  Touch Screen Assembly Replacement: passo 6, imagem 2 %32
    • Once finished removing all seven Phillips screws we can begin to separate the first layer of the screen and back.
    • Here you will need to use your plastic pry tool for this step. Along the edges of the device you should be able to pry on the plastic side of the screen to loosen it.
    • There is also a notch shown in picture 2 you will need to push in.
  7. LG 305C  Touch Screen Assembly Replacement: passo 7, imagem 1 %32 LG 305C  Touch Screen Assembly Replacement: passo 7, imagem 2 %32 LG 305C  Touch Screen Assembly Replacement: passo 7, imagem 3 %32
    • Once loose you can remove the front end of the screen by gentle swinging it out from its notched in position. like so in the three movements
  8. LG 305C  Touch Screen Assembly Replacement: passo 8, imagem 1 %32 LG 305C  Touch Screen Assembly Replacement: passo 8, imagem 2 %32
    • This step we will be separating the motherboard and the plastic screen mold.
    • You will need to gentle with your finger pry the Touch screen connection that is attached to the motherboard off.
    • Once detached you will gentle separate the two pieces.
    • When finished it should look like picture 2.
Conclusão
alex Benitez
Membro desde: 10/24/16
103 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 1-3, Bennett Fall 2016 Membro de Texas Tech, Team 1-3, Bennett Fall 2016
TTU-BENNETT-F16S1G3
Membros da 6
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 313
