Ir para o conteúdo principal
LG 305C MicroSD card Replacement
O que você precisa
  1. LG 305C MicroSD card Replacement, Battery: passo 1, imagem 1 %32
    • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
  2. LG 305C MicroSD card Replacement: passo 2, imagem 1 %32
    • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
  3. LG 305C MicroSD card Replacement, MicroSD card: passo 3, imagem 1 %32
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
Conclusão
Equipe
IUPUI, Team S6-G1, Baechle Spring 2018 Membro de IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 50
Ao todo: 388
