Ir para o conteúdo principal
LCD Screen Replacement
O que você precisa
    1. LCD Screen  Replacement, Battery Door: passo 1, imagem 1 %32
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Pergunte ao FixBot
      Comentar
    2. LCD Screen  Replacement: passo 2, imagem 1 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Pergunte ao FixBot
      Comentar
    3. LCD Screen  Replacement: passo 3, imagem 1 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Pergunte ao FixBot
      Comentar
    4. LCD Screen  Replacement: passo 4, imagem 1 %32 LCD Screen  Replacement: passo 4, imagem 2 %32
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. LCD Screen  Replacement: passo 5, imagem 1 %32
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Pergunte ao FixBot
      Comentar
    6. LCD Screen  Replacement: passo 6, imagem 1 %32 LCD Screen  Replacement: passo 6, imagem 2 %32 LCD Screen  Replacement: passo 6, imagem 3 %32
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Pergunte ao FixBot
      Comentar
    7. LCD Screen  Replacement: passo 7, imagem 1 %32 LCD Screen  Replacement: passo 7, imagem 2 %32 LCD Screen  Replacement: passo 7, imagem 3 %32
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Pergunte ao FixBot
      Comentar
    1. LCD Screen  Replacement, LCD Screen: passo 8, imagem 1 %32 LCD Screen  Replacement, LCD Screen: passo 8, imagem 2 %32 LCD Screen  Replacement, LCD Screen: passo 8, imagem 3 %32
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro de USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 985
