Ir para o conteúdo principal
Kyocera Hydro Life Charging Port Replacement
O que você precisa
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Kyocera Hydro Life Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: passo 2, imagem 1 %32 Kyocera Hydro Life Charging Port Replacement: passo 2, imagem 2 %32 Kyocera Hydro Life Charging Port Replacement: passo 2, imagem 3 %32
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: passo 3, imagem 1 %32
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: passo 4, imagem 1 %32 Kyocera Hydro Life Charging Port Replacement: passo 4, imagem 2 %32 Kyocera Hydro Life Charging Port Replacement: passo 4, imagem 3 %32
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: passo 5, imagem 1 %32 Kyocera Hydro Life Charging Port Replacement: passo 5, imagem 2 %32 Kyocera Hydro Life Charging Port Replacement: passo 5, imagem 3 %32
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: passo 6, imagem 1 %32 Kyocera Hydro Life Charging Port Replacement: passo 6, imagem 2 %32
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: passo 7, imagem 1 %32
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: passo 9, imagem 1 %32
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: passo 10, imagem 1 %32
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,028
