Ir para o conteúdo principal
Kyocera DuraForce PRO Battery Replacement
O que você precisa
  1. Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: passo 1, imagem 1 %32 Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: passo 1, imagem 2 %32 Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: passo 1, imagem 3 %32
    • Make sure to power down phone before starting.
    • Insert the opening pick/tool into the slit between the case and the body of the phone. It can be easier to insert near buttons. Make your way around the case as you use the pick/tool to lift the cover from the body.
    • Once completely loose lift the cover off and set aside.
    • This is a good opportunity to blow out any dust that has accumulated.
  2. Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: passo 2, imagem 1 %32 Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: passo 2, imagem 2 %32 Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: passo 2, imagem 3 %32
    • Using your Phillips 000 remove the eight screws found in the waterproof cover.
    • Make sure to keep your screws in a small bowl or cup to keep them from rolling off the table.
    • Once the screws are removed, take your pick tool and make your way around the case as you use the pick/tool to lift the waterproof cover from the body.
    • Once loosen by the pick carefully remove the cover from the base and set aside.
    • Be careful of the buttons and port covers that will loosen and come off. If they come completely off set them aside and remember which location/direction they go.
    • Also be careful of the orange seal that is embedded in the waterproof cover. If it comes loose you can push back in place with tweezers.
  3. Kyocera DuraForce PRO Battery Replacement, Remove Battery: passo 3, imagem 1 %32 Kyocera DuraForce PRO Battery Replacement, Remove Battery: passo 3, imagem 2 %32 Kyocera DuraForce PRO Battery Replacement, Remove Battery: passo 3, imagem 3 %32
    • Highly recommend making sure you are grounded before removing the battery. You will be handling areas that could cause damage if you accidentally create a static discharge.
    • You will notice a disclaimer on the battery that states that if you remove the battery you void the warranty. Make sure your warranty has expired before performing this repair.
    • Starting near the lower area of the phone, carefully press the battery towards the top of the phone and then lift up.
    • Lift the battery up and over the top of the phone to expose the battery cable and port.
    • Using tweezers and opening tool, flip the lock on the port and carefully pull out the cable.
Conclusão
19 outras pessoas executaram este guia.
Mike Rote
Membro desde: 02/01/18
632 Reputação
Autoria de 1 guia
7 comentários
As of June 2018 there is no new SCP-67LBPS , battery replacement available for the pro.. only used batteries from cannibalized phones.
for anyone interested here is a video of df pro battery removal
https://youtu.be/gz53p6mkAHA
freewillieklr - Responder
I am going to try method.
Angel Fulton - Responder
No new battery to buy for this phone? Maybe can buy from Kyocera?
danwat1234 - Responder
FidgetFidget OEM New Battery for Kyocera Duraforce PRO E6820 E6810 SCP-67LBPS 3240mAh 3.8V https://www.amazon.com/dp/B07H2BNLCZ/ref...
Andrew Messer -
Shopping sites in Japan are still selling SCP-67LBPS . Maybe they can’t send batteries to US. If you have a friend in Japan. You can ask him/her to get it.
https://www.denchi-mall.org/mobile-phone...
Nobuaki Yamashita - Responder
Very helpful in reassembling phone and reinserting tiny side buttons
Andrew Messer - Responder
WalMart, Amazon, BatteryClub, Ebay, and Battery Mart all have replacement batteries. Some have complete kits with screwdrivers, and plastic priers. Just do a search on the part number.
Sam Walker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 56
Últimos 30 dias: 242
Duração total: 26,420
