Ir para o conteúdo principal
Kurio Xtreme Camera Replacement
O que você precisa
    1. Kurio Xtreme Camera Replacement, Back Panel: passo 1, imagem 1 %32
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      Pergunte ao FixBot
      Comentar
    2. Kurio Xtreme Camera Replacement: passo 2, imagem 1 %32 Kurio Xtreme Camera Replacement: passo 2, imagem 2 %32
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      Pergunte ao FixBot
      Comentar
    3. Kurio Xtreme Camera Replacement: passo 3, imagem 1 %32 Kurio Xtreme Camera Replacement: passo 3, imagem 2 %32 Kurio Xtreme Camera Replacement: passo 3, imagem 3 %32
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      Pergunte ao FixBot
      Comentar
    1. Kurio Xtreme Camera Replacement, Camera: passo 4, imagem 1 %32
      • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
      Pergunte ao FixBot
      Comentar
    2. Kurio Xtreme Camera Replacement: passo 5, imagem 1 %32 Kurio Xtreme Camera Replacement: passo 5, imagem 2 %32 Kurio Xtreme Camera Replacement: passo 5, imagem 3 %32
      • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
      • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Mallory Myers
Membro desde: 09/22/15
1.190 Reputação
Autoria de 7 guias
Equipe
Baylor, Team 6-10, Williams Fall 2015 Membro de Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 468
