Introdução
If your Kurio Xtreme is not charging or is not holding a charge, follow these steps to remove the faulty battery. Before proceeding, make sure that you have a soldering iron and know how to use it.
O que você precisa
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
Carefully lift the battery out of the device.
2 comentários
Does it have a certain battery or can a different battery fit?
