Ir para o conteúdo principal
Kurio Touch 4S Speaker Replacement
O que você precisa
  1. Kurio Touch 4S Speaker  Replacement, Speakers: passo 1, imagem 1 %32
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: passo 2, imagem 1 %32 Kurio Touch 4S Speaker  Replacement: passo 2, imagem 2 %32 Kurio Touch 4S Speaker  Replacement: passo 2, imagem 3 %32
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: passo 3, imagem 1 %32 Kurio Touch 4S Speaker  Replacement: passo 3, imagem 2 %32
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: passo 4, imagem 1 %32
  5. Kurio Touch 4S Speaker  Replacement: passo 5, imagem 1 %32
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: passo 6, imagem 1 %32
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: passo 7, imagem 1 %32
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: passo 8, imagem 1 %32
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Conclusão
Uma outra pessoa concluiu este guia.
Moin Khan
Membro desde: 01/21/15
234 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-5, Brown Winter 2015 Membro de USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 179
