Ir para o conteúdo principal
Kurio Touch 4S Battery Replacement
O que você precisa
  1. Kurio Touch 4S Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: passo 2, imagem 1 %32 Kurio Touch 4S Battery Replacement: passo 2, imagem 2 %32 Kurio Touch 4S Battery Replacement: passo 2, imagem 3 %32
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: passo 3, imagem 1 %32 Kurio Touch 4S Battery Replacement: passo 3, imagem 2 %32 Kurio Touch 4S Battery Replacement: passo 3, imagem 3 %32
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: passo 4, imagem 1 %32
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: passo 6, imagem 1 %32
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Conclusão
3 outras pessoas executaram este guia.
Khalid AlTamimi
Membro desde: 01/21/15
275 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-5, Brown Winter 2015 Membro de USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
Membros da 3
Autoria de 10 guias
2 comentários
do you know where to buy a replacement battery ?
Phil Bowring - Responder
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,628
