Ir para o conteúdo principal
Kurio 7 Back Panel Replacement
O que você precisa
    1. Kurio 7 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 Kurio 7 Back Panel Replacement, Back Panel: passo 1, imagem 2 %32 Kurio 7 Back Panel Replacement, Back Panel: passo 1, imagem 3 %32
      • Begin by removing the rubber cover from the Kurio 7.
      Pergunte ao FixBot
      Comentar
    2. Kurio 7 Back Panel Replacement: passo 2, imagem 1 %32 Kurio 7 Back Panel Replacement: passo 2, imagem 2 %32
      • Remove the four 30 mm Phillips #00 screws from the outer case.
      Pergunte ao FixBot
      Comentar
    3. Kurio 7 Back Panel Replacement: passo 3, imagem 1 %32 Kurio 7 Back Panel Replacement: passo 3, imagem 2 %32
      • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
      • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
      • Be careful not to break off the tabs that hold the front cover and the back cover together.
      Pergunte ao FixBot
      Comentar
    4. Kurio 7 Back Panel Replacement: passo 4, imagem 1 %32 Kurio 7 Back Panel Replacement: passo 4, imagem 2 %32
      • Once all of the tabs are removed, the back cover should come off easily.
      • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
      Pergunte ao FixBot
      Comentar
Conclusão
Replace with a new back panel. To reassemble your device, follow these instructions in reverse order.
Eric Rice
Membro desde: 04/14/14
913 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-36, Maness Spring 2014 Membro de Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Membros
Autoria de 21 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 2,968
