Ir para o conteúdo principal
Krups CafeExpress FMA110 Disassembly
O que você precisa
  1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: passo 1, imagem 1 %32 Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
    • Remove the metal plate.
    Pergunte ao FixBot
    Comentar
  2. Krups CafeExpress FMA110 Disassembly: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
    Pergunte ao FixBot
    Comentar
  3. Krups CafeExpress FMA110 Disassembly: passo 3, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 3, imagem 2 %32
    • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
    Pergunte ao FixBot
    Comentar
  4. Krups CafeExpress FMA110 Disassembly: passo 4, imagem 1 %32
    • Carefully pull the silicon tubing off of the metal tube.
    Pergunte ao FixBot
    Comentar
  5. Krups CafeExpress FMA110 Disassembly: passo 5, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 5, imagem 2 %32
    • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
    Pergunte ao FixBot
    Comentar
  6. Krups CafeExpress FMA110 Disassembly: passo 6, imagem 1 %32
    • Carefully remove the silicon tubing from the upper reservoir.
    Pergunte ao FixBot
    Comentar
  7. Krups CafeExpress FMA110 Disassembly: passo 7, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
    Pergunte ao FixBot
    Comentar
  8. Krups CafeExpress FMA110 Disassembly: passo 8, imagem 1 %32
    • Separate the base of the device from the upper reservoir.
    Pergunte ao FixBot
    Comentar
  9. Krups CafeExpress FMA110 Disassembly: passo 9, imagem 1 %32
    • Push the switch out from the inside, releasing it from the plastic base.
    Pergunte ao FixBot
    Comentar
  10. Krups CafeExpress FMA110 Disassembly: passo 10, imagem 1 %32
    • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
    Pergunte ao FixBot
    Comentar
  11. Krups CafeExpress FMA110 Disassembly: passo 11, imagem 1 %32
    • Slide the rest of the switch back through the hole in the base.
    Pergunte ao FixBot
    Comentar
  12. Krups CafeExpress FMA110 Disassembly: passo 12, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 12, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
    Pergunte ao FixBot
    Comentar
  13. Krups CafeExpress FMA110 Disassembly: passo 13, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 13, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
    Pergunte ao FixBot
    Comentar
  14. Krups CafeExpress FMA110 Disassembly: passo 14, imagem 1 %32
    • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
    Pergunte ao FixBot
    Comentar
  15. Krups CafeExpress FMA110 Disassembly: passo 15, imagem 1 %32
    • Disconnect the wire connectors from the thermal switch.
    Pergunte ao FixBot
    Comentar
  16. Krups CafeExpress FMA110 Disassembly: passo 16, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
    Pergunte ao FixBot
    Comentar
  17. Krups CafeExpress FMA110 Disassembly: passo 17, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 17, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
    • Separate the hot plate from its frame.
    Pergunte ao FixBot
    Comentar
  18. Krups CafeExpress FMA110 Disassembly: passo 18, imagem 1 %32 Krups CafeExpress FMA110 Disassembly: passo 18, imagem 2 %32
    • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 44
Ao todo: 840
