Ir para o conteúdo principal
Koosh Vortex Tornado Loading Spring Replacement
O que você precisa
  1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: passo 1, imagem 1 %32
    • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
    Pergunte ao FixBot
    Comentar
  2. Koosh Vortex Tornado Loading Spring Replacement: passo 2, imagem 1 %32
    • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
    Pergunte ao FixBot
    Comentar
  3. Koosh Vortex Tornado Loading Spring Replacement: passo 3, imagem 1 %32
    • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
    Pergunte ao FixBot
    Comentar
  4. Koosh Vortex Tornado Loading Spring Replacement, Trigger: passo 4, imagem 1 %32
    • Slide the barrel shield and shield slide off of the gun and set aside.
    Pergunte ao FixBot
    Comentar
  5. Koosh Vortex Tornado Loading Spring Replacement: passo 5, imagem 1 %32
    • Slide the rubber ring off of the barrel and set it aside.
    Pergunte ao FixBot
    Comentar
  6. Koosh Vortex Tornado Loading Spring Replacement: passo 6, imagem 1 %32
    • Lift the yellow trigger from its pin and set aside.
    Pergunte ao FixBot
    Comentar
  7. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
    Pergunte ao FixBot
    Comentar
  8. Koosh Vortex Tornado Loading Spring Replacement: passo 8, imagem 1 %32
    • Lift the yellow lever bar out of place and set aside.
    Pergunte ao FixBot
    Comentar
  9. Koosh Vortex Tornado Loading Spring Replacement: passo 9, imagem 1 %32
    • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
    • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
    Pergunte ao FixBot
    Comentar
  10. Koosh Vortex Tornado Loading Spring Replacement: passo 10, imagem 1 %32
    • Pull the shell of the central firing assembly aside off (contains the loading spring).
    Pergunte ao FixBot
    Comentar
  11. Koosh Vortex Tornado Loading Spring Replacement: passo 11, imagem 1 %32 Koosh Vortex Tornado Loading Spring Replacement: passo 11, imagem 2 %32
    • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
    • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
    Pergunte ao FixBot
    Comentar
Conclusão
Lingbin Meng
Membro desde: 02/16/16
204 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-4, Harley Spring 2016 Membro de IUPUI, Team 2-4, Harley Spring 2016
IUPUI-HARLEY-S16S2G4
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 25
Últimos 30 dias: 77
Ao todo: 1,102
