Ir para o conteúdo principal
Kodak Signet 35 Shutter Spring Replacement
O que você precisa
  1. Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: passo 1, imagem 1 %32 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: passo 1, imagem 2 %32 Kodak Signet 35 Shutter Spring Replacement, Shutter Spring: passo 1, imagem 3 %32
    • While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
  2. Kodak Signet 35 Shutter Spring Replacement: passo 2, imagem 1 %32 Kodak Signet 35 Shutter Spring Replacement: passo 2, imagem 2 %32
    • Remove the lever from the stopper by pushing it back and then upwards.
  3. Kodak Signet 35 Shutter Spring Replacement: passo 3, imagem 1 %32 Kodak Signet 35 Shutter Spring Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the stopper by lifting it upwards with the tweezers.
  4. Kodak Signet 35 Shutter Spring Replacement: passo 4, imagem 1 %32 Kodak Signet 35 Shutter Spring Replacement: passo 4, imagem 2 %32 Kodak Signet 35 Shutter Spring Replacement: passo 4, imagem 3 %32
    • Using tweezers, unhitch the spring from the base and remove it by lifting upwards.
Conclusão
Mellyssa Greene
Membro desde: 09/07/16
134 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 6-3, Remmell Fall 2016 Membro de USF Tampa, Team 6-3, Remmell Fall 2016
USFT-REMMELL-F16S6G3
4 Membros
Autoria de 9 guias
2Comentários do guia
What kind of spring can be used to replace it or how would one revitalize the old spring?
Ben Le - Responder Compartilhar
What does “front lens assembly” look like? what parts do I have to unscrew?
Shawn Reynolds - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 25
Últimos 30 dias: 65
Ao todo: 3,235
