Introdução
If the shutter on your Kodak Signet 35 isn't working properly, then the shutter spring may need to be cleaned or replaced. This guide will show you how. Please make sure you have all the necessary tools, as well as a clean and stable surface on which to work, before you start these steps.
O que você precisa
While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
2Comentários do guia
What kind of spring can be used to replace it or how would one revitalize the old spring?
What does “front lens assembly” look like? what parts do I have to unscrew?
