Ir para o conteúdo principal
Kodak S100 EF Flash Replacement
O que você precisa
  1. Kodak S100 EF Flash Replacement, Front Cover: passo 1, imagem 1 %32
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Flash Replacement: passo 2, imagem 1 %32
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Flash Replacement: passo 3, imagem 1 %32
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Flash Replacement, Flash: passo 4, imagem 1 %32
    • Once the front cover is off, desolder the connections at both ends of the flash.
    • If unfamiliar with soldering, refer to the guide Como soldar e dessoldar contatos
Conclusão
Uma outra pessoa concluiu este guia.
Nick
Membro desde: 04/26/11
4 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 25-28, Garner Spring 2011 Membro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 2,620
