Ir para o conteúdo principal
Kodak Easyshare C813 Shutter Button Replacement
O que você precisa
  1. Kodak Easyshare C813 Shutter Button Replacement, Battery: passo 1, imagem 1 %32
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Shutter Button Replacement: passo 2, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 2, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 2, imagem 3 %32
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
  4. Kodak Easyshare C813 Shutter Button Replacement: passo 4, imagem 1 %32
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Shutter Button Replacement: passo 5, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 5, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 5, imagem 3 %32
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Shutter Button Replacement: passo 6, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 6, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 6, imagem 3 %32
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Shutter Button Replacement: passo 7, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 7, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 7, imagem 3 %32
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Shutter Button Replacement: passo 8, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 8, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 8, imagem 3 %32
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: passo 9, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: passo 9, imagem 2 %32
    • Open the battery door.
  10. Kodak Easyshare C813 Shutter Button Replacement: passo 10, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 10, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 10, imagem 3 %32
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Shutter Button Replacement: passo 11, imagem 1 %32
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: passo 12, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: passo 12, imagem 2 %32
    • The shutter button is held on to the front cover by three screws
    • Hold the shutter button in place
    • Use a Philips 00 screwdriver to remove the screws.
    • Careful that the power and flash button do not fall off
  13. Kodak Easyshare C813 Shutter Button Replacement: passo 13, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 13, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 13, imagem 3 %32
    • Keep the shutter button in place while removing the circular metal plate
    • Remove the shutter button by allowing it to fall into your hand
  14. Kodak Easyshare C813 Shutter Button Replacement: passo 14, imagem 1 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 14, imagem 2 %32 Kodak Easyshare C813 Shutter Button Replacement: passo 14, imagem 3 %32
    • Hold down the shutter button portion of the selector dial
    • Press down the red tabs and slowly relieve pressure on the shutter button
    • Press down on the center red stick
    • Careful not to lose the spring
    • Tool shown is Found here
  15. Kodak Easyshare C813 Shutter Button Replacement: passo 15, imagem 1 %32
    • If cleaning, remove dirt from button
    • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
Conclusão
Susan Marano
Membro desde: 04/15/10
339 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 24-22, Regan Spring 2010 Membro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Membros
Autoria de 22 guias
1Comentário do guia
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 8,038
