Ir para o conteúdo principal
Kodak Easyshare C183 Lens Assembly Replacement
O que você precisa
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, imagem 3 %32
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
  2. Kodak Easyshare C183 Lens Assembly Replacement: passo 2, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 2, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 2, imagem 3 %32
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
  3. Kodak Easyshare C183 Lens Assembly Replacement: passo 3, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 3, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 3, imagem 3 %32
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
  4. Kodak Easyshare C183 Lens Assembly Replacement: passo 4, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 4, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 4, imagem 3 %32
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
  5. Kodak Easyshare C183 Lens Assembly Replacement: passo 5, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 5, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 5, imagem 3 %32
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
  6. Kodak Easyshare C183 Lens Assembly Replacement: passo 6, imagem 1 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 6, imagem 2 %32 Kodak Easyshare C183 Lens Assembly Replacement: passo 6, imagem 3 %32
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
  7. Kodak Easyshare C183 Lens Assembly Replacement: passo 7, imagem 1 %32
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
Conclusão
oldturkey03
Membro desde: 09/29/10
813.468 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 702 guias
2 comentários
ممنون از اطلاعات تان
hamid kaker - Responder
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 -
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 2,012
