Ir para o conteúdo principal
Kodak EasyShare M381 Screen Replacement
O que você precisa
    1. Kodak EasyShare M381 Screen Replacement, Battery: passo 1, imagem 1 %32 Kodak EasyShare M381 Screen Replacement, Battery: passo 1, imagem 2 %32
      • First, press in and slide forward the battery latch as indicated by the arrow.
      Pergunte ao FixBot
      Comentar
    2. Kodak EasyShare M381 Screen Replacement: passo 2, imagem 1 %32
      • Press down on battery until you hear a click and release it. Battery should easily slide out.
      Pergunte ao FixBot
      Comentar
    1. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, imagem 1 %32 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, imagem 2 %32 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, imagem 3 %32
      • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
      • Using a magnetized surface to keep from losing screws may be very helpful.
      Pergunte ao FixBot
      Comentar
    2. Kodak EasyShare M381 Screen Replacement: passo 4, imagem 1 %32 Kodak EasyShare M381 Screen Replacement: passo 4, imagem 2 %32
      • Using both hands, carefully pull the frame apart from the camera.
      Pergunte ao FixBot
      Comentar
    1. Kodak EasyShare M381 Screen Replacement, Screen: passo 5, imagem 1 %32
      • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
      Pergunte ao FixBot
      Comentar
    2. Kodak EasyShare M381 Screen Replacement: passo 6, imagem 1 %32
      • Remove dial button located on top of camera, by gently pulling up.
      Pergunte ao FixBot
      Comentar
    3. Kodak EasyShare M381 Screen Replacement: passo 7, imagem 1 %32 Kodak EasyShare M381 Screen Replacement: passo 7, imagem 2 %32
      • Starting at one side, carefully work the chrome frame off of the camera itself.
      • Be careful not to disturb the shutter or flash buttons on top of the camera.
      Pergunte ao FixBot
      Comentar
    4. Kodak EasyShare M381 Screen Replacement: passo 8, imagem 1 %32
      • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
      Pergunte ao FixBot
      Comentar
    5. Kodak EasyShare M381 Screen Replacement: passo 9, imagem 1 %32 Kodak EasyShare M381 Screen Replacement: passo 9, imagem 2 %32 Kodak EasyShare M381 Screen Replacement: passo 9, imagem 3 %32
      • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
      • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
      • Slide panel away from camera.
      Pergunte ao FixBot
      Comentar
    6. Kodak EasyShare M381 Screen Replacement: passo 10, imagem 1 %32 Kodak EasyShare M381 Screen Replacement: passo 10, imagem 2 %32
      • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
      • Screen should now be detached. Gently lift it away from the base of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 906
