Ir para o conteúdo principal
Kodak EasyShare C913 LCD Screen Replacement
O que você precisa
    1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement, Batteries: passo 1, imagem 3 %32
      • Position the camera with the bottom facing up.
      • Slide the battery cover in the direction of the arrow with your finger gently.
      • Remove the batteries
      Pergunte ao FixBot
      Comentar
    1. Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement, Back Case: passo 2, imagem 3 %32
      • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
      • 2 screws on the left, 2 screws on the right, 3 screws on the bottom
      Pergunte ao FixBot
      Comentar
    2. Kodak EasyShare C913 LCD Screen Replacement: passo 3, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 3, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 3, imagem 3 %32
      • Firmly grasp the back of the camera and pull the casing away.
      Pergunte ao FixBot
      Comentar
    1. Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement, Front Case: passo 4, imagem 3 %32
      • Keep the battery door open
      • Firmly grasp the front casing and pull it away from the camera.
      Pergunte ao FixBot
      Comentar
    1. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: passo 5, imagem 3 %32
      • Look at the LCD casing and find the two smaller solder joints. One on either side of the camera secures the circuit board's casing. These are usually shiny and metallic points where the casing connects to the board.
      • Apply the tip of the heated solder to the first joint to remove it. Continue with the other side.
      Pergunte ao FixBot
      Comentar
    2. Kodak EasyShare C913 LCD Screen Replacement: passo 6, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 6, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 6, imagem 3 %32
      • Gently grasp the lower right side of LCD screen.
      • Lift the screen out of its casing.
      • Remove the 3 mm screw from the LCD casing using a #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Kodak EasyShare C913 LCD Screen Replacement: passo 7, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 7, imagem 2 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 7, imagem 3 %32
      • Gently grab the sides of the LCD casing and remove it from the camera.
      Pergunte ao FixBot
      Comentar
    4. Kodak EasyShare C913 LCD Screen Replacement: passo 8, imagem 1 %32 Kodak EasyShare C913 LCD Screen Replacement: passo 8, imagem 2 %32
      • Lift the black tab gently with your finger.
      • Gently remove ribbon from underneath black tab.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Alan Galarza
Membro desde: 10/03/10
84 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-51, Amido Fall 2010 Membro de Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 5,072
