Ir para o conteúdo principal
Kobo Mini Disassembly
O que você precisa
  1. Kobo Mini Disassembly, Kobo Mini Disassembly: passo 1, imagem 1 %32 Kobo Mini Disassembly, Kobo Mini Disassembly: passo 1, imagem 2 %32
    • Pull on the corner to remove the cover.
    Pergunte ao FixBot
    Comentar
  2. Kobo Mini Disassembly: passo 2, imagem 1 %32
    • Remove the six screws.
    • Remove the back of the device.
    Pergunte ao FixBot
    Comentar
  3. Kobo Mini Disassembly: passo 3, imagem 1 %32
    • Remove the four screws from the mother board.
    • Remove the screen connector and the battery connector.
    • Remove the micro SD card.
    • Remove the motherboard from the chassis.
    Pergunte ao FixBot
    Comentar
  4. Kobo Mini Disassembly: passo 4, imagem 1 %32 Kobo Mini Disassembly: passo 4, imagem 2 %32
    • Remove the four screws from the screen frame.
    • Remove the screen
    Pergunte ao FixBot
    Comentar
  5. Kobo Mini Disassembly: passo 5, imagem 1 %32
    • And we finally finished.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
3 outras pessoas executaram este guia.
Gabriel Bédard
Membro desde: 06/07/18
357 Reputação
Autoria de 1 guia
9Comentários do guia
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - Responder Compartilhar
Yes I think
Gabriel Bédard - Responder Compartilhar
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - Responder Compartilhar
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - Responder Compartilhar
Yes you just need to pull it from the motherboard
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 141
Ao todo: 7,550
