Ir para o conteúdo principal
Kobo Clara HD Repairs
O que você precisa
  1. Kobo Clara HD Repairs, Before starting: passo 1, imagem 1 %32
    • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
    Pergunte ao FixBot
    Comentar
  2. Kobo Clara HD Repairs, Back cover: passo 2, imagem 1 %32 Kobo Clara HD Repairs, Back cover: passo 2, imagem 2 %32 Kobo Clara HD Repairs, Back cover: passo 2, imagem 3 %32
    • Stick a plastic spudger into the gap between the front bezel and the back cover.
    • The back cover is held on by small plastic notches.
    • Slide the spudger along the seam to release the back cover.
    • Pry all the way around until the back cover pops free.
    Pergunte ao FixBot
    Comentar
  3. Kobo Clara HD Repairs, Battery: passo 3, imagem 1 %32 Kobo Clara HD Repairs, Battery: passo 3, imagem 2 %32 Kobo Clara HD Repairs, Battery: passo 3, imagem 3 %32
    • Gently pry up the white battery connector to pop it out of its bracket.
    Pergunte ao FixBot
    Comentar
  4. Kobo Clara HD Repairs, Screen connectors: passo 4, imagem 1 %32 Kobo Clara HD Repairs, Screen connectors: passo 4, imagem 2 %32 Kobo Clara HD Repairs, Screen connectors: passo 4, imagem 3 %32
    • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
    • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
    • Slide the ribbon cables out of the ZIF sockets.
    Pergunte ao FixBot
    Comentar
  5. Kobo Clara HD Repairs, Battery: passo 5, imagem 1 %32 Kobo Clara HD Repairs, Battery: passo 5, imagem 2 %32
    • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
    Pergunte ao FixBot
    Comentar
  6. Kobo Clara HD Repairs, Storage: passo 6, imagem 1 %32 Kobo Clara HD Repairs, Storage: passo 6, imagem 2 %32
    • All the storage is on a microSD card hidden inside the device.
    • Swap it out at your own risk.
    Pergunte ao FixBot
    Comentar
  7. Kobo Clara HD Repairs, Logic board: passo 7, imagem 1 %32 Kobo Clara HD Repairs, Logic board: passo 7, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
    • Lift the logic board out from the top of the device.
    • There is a black sheet of plastic that sits under the logic board.
    Pergunte ao FixBot
    Comentar
  8. Kobo Clara HD Repairs: passo 8, imagem 1 %32 Kobo Clara HD Repairs: passo 8, imagem 2 %32
    • To reassemble your device, follow these steps in reverse order.
    • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
3 outras pessoas executaram este guia.
Sparky
Membro desde: 03/15/26
1.535 Reputação
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 83
Últimos 30 dias: 463
Ao todo: 1,221
