Ir para o conteúdo principal
KitchenAid KSB5CR Power Cable Replacement
O que você precisa
    1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, imagem 1 %32 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, imagem 2 %32 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, imagem 3 %32
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: passo 2, imagem 1 %32
      • Lift the back panel up, sliding it along the power cord.
      Pergunte ao FixBot
      Comentar
    1. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: passo 3, imagem 1 %32
      • Lift up on the power cable to pop it out of its holder.
      Pergunte ao FixBot
      Comentar
    2. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: passo 4, imagem 1 %32 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: passo 4, imagem 2 %32
      • Be gentle with the knife or you will break the circuit board.
      • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
      • Repeat this process with the black copper wire.
      Pergunte ao FixBot
      Comentar
    3. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: passo 5, imagem 1 %32 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: passo 5, imagem 2 %32
      • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 12-5, Forte Fall 2014 Membro de Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 953
