Ir para o conteúdo principal
KitchenAid KHM512ER Power Cord Replacement
O que você precisa
    1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement, Power Cord: passo 1, imagem 2 %32
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Pergunte ao FixBot
      Comentar
    2. KitchenAid KHM512ER Power Cord Replacement: passo 2, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement: passo 2, imagem 2 %32 KitchenAid KHM512ER Power Cord Replacement: passo 2, imagem 3 %32
      • Use a plastic opening tool to remove the speed knob.
      • Pop up the panel with a plastic opening tool.
      • Use a plastic opening tool to pry the white plastic switch assembly out.
      Pergunte ao FixBot
      Comentar
    3. KitchenAid KHM512ER Power Cord Replacement: passo 3, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement: passo 3, imagem 2 %32
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. KitchenAid KHM512ER Power Cord Replacement: passo 4, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement: passo 4, imagem 2 %32 KitchenAid KHM512ER Power Cord Replacement: passo 4, imagem 3 %32
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      Pergunte ao FixBot
      Comentar
    5. KitchenAid KHM512ER Power Cord Replacement: passo 5, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement: passo 5, imagem 2 %32 KitchenAid KHM512ER Power Cord Replacement: passo 5, imagem 3 %32
      • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      Pergunte ao FixBot
      Comentar
    6. KitchenAid KHM512ER Power Cord Replacement: passo 6, imagem 1 %32 KitchenAid KHM512ER Power Cord Replacement: passo 6, imagem 2 %32 KitchenAid KHM512ER Power Cord Replacement: passo 6, imagem 3 %32
      • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
      • Once it's loose, remove it with your fingers.
      • Pull the power cord through the hole.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Brad Daniels
Membro desde: 02/10/16
636 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-3, Sullivan Spring 2016 Membro de USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Membros
Autoria de 9 guias
1Comentário do guia
where to find this cord?
Markian G.G. - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 46
Ao todo: 4,496
