Ir para o conteúdo principal
KitchenAid KHM512ER Motor Replacement
O que você precisa
  1. KitchenAid KHM512ER Motor Replacement, Motor: passo 1, imagem 1 %32 KitchenAid KHM512ER Motor Replacement, Motor: passo 1, imagem 2 %32
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
    Pergunte ao FixBot
    Comentar
  2. KitchenAid KHM512ER Motor Replacement: passo 2, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 2, imagem 2 %32
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    Pergunte ao FixBot
    Comentar
  3. KitchenAid KHM512ER Motor Replacement: passo 3, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 3, imagem 2 %32
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
    Pergunte ao FixBot
    Comentar
  4. KitchenAid KHM512ER Motor Replacement: passo 4, imagem 1 %32 KitchenAid KHM512ER Motor Replacement: passo 4, imagem 2 %32 KitchenAid KHM512ER Motor Replacement: passo 4, imagem 3 %32
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
    Pergunte ao FixBot
    Comentar
Conclusão
[deleted]
Membro desde: 02/10/16
134 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 41
Ao todo: 5,457
