Ir para o conteúdo principal
KitchenAid KHM512ER Eject Button Spring Replacement
O que você precisa
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, imagem 1 %32 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, imagem 2 %32
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      Pergunte ao FixBot
      Comentar
    2. KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, imagem 1 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, imagem 2 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, imagem 3 %32
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      Pergunte ao FixBot
      Comentar
    3. KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, imagem 1 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, imagem 2 %32
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, imagem 1 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, imagem 2 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, imagem 3 %32
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      Pergunte ao FixBot
      Comentar
    5. KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, imagem 1 %32 KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, imagem 2 %32
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 2-3, Sullivan Spring 2016 Membro de USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 2,116
