Ir para o conteúdo principal
Kindle Voyage Vibrator Replacement
O que você precisa
  1. Kindle Voyage Vibrator Replacement, Back Panel: passo 1, imagem 1 %32 Kindle Voyage Vibrator Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    Pergunte ao FixBot
    Comentar
  2. Kindle Voyage Vibrator Replacement: passo 2, imagem 1 %32
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
    Pergunte ao FixBot
    Comentar
  3. Kindle Voyage Vibrator Replacement: passo 3, imagem 1 %32 Kindle Voyage Vibrator Replacement: passo 3, imagem 2 %32 Kindle Voyage Vibrator Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, the back panel can slide off the device.
    Pergunte ao FixBot
    Comentar
  4. Kindle Voyage Vibrator Replacement: passo 4, imagem 1 %32 Kindle Voyage Vibrator Replacement: passo 4, imagem 2 %32
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    Pergunte ao FixBot
    Comentar
  5. Kindle Voyage Vibrator Replacement, Vibrator: passo 5, imagem 1 %32 Kindle Voyage Vibrator Replacement, Vibrator: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
    Pergunte ao FixBot
    Comentar
  6. Kindle Voyage Vibrator Replacement: passo 6, imagem 1 %32 Kindle Voyage Vibrator Replacement: passo 6, imagem 2 %32 Kindle Voyage Vibrator Replacement: passo 6, imagem 3 %32
    • Gently peel the vibrator off of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Sean Yap
Membro desde: 01/22/15
1.508 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 19-12, Maness Winter 2015 Membro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membros
Autoria de 13 guias
1Comentário do guia
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
Sharon Crowley - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 1,850
