Ir para o conteúdo principal
Kindle Voyage Screen Replacement
O que você precisa
  1. Kindle Voyage Screen Replacement, Back Panel: passo 1, imagem 1 %32 Kindle Voyage Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    Pergunte ao FixBot
    Comentar
  2. Kindle Voyage Screen Replacement: passo 2, imagem 1 %32
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
    Pergunte ao FixBot
    Comentar
  3. Kindle Voyage Screen Replacement: passo 3, imagem 1 %32 Kindle Voyage Screen Replacement: passo 3, imagem 2 %32 Kindle Voyage Screen Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, the back panel can slide off the device.
    Pergunte ao FixBot
    Comentar
  4. Kindle Voyage Screen Replacement: passo 4, imagem 1 %32 Kindle Voyage Screen Replacement: passo 4, imagem 2 %32
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    Pergunte ao FixBot
    Comentar
  5. Kindle Voyage Screen Replacement, Screen: passo 5, imagem 1 %32 Kindle Voyage Screen Replacement, Screen: passo 5, imagem 2 %32
    • Use a spudger to push up the black tabs on all three ribbon cables.
    • Once the tabs are open, gently pull the ribbon cables out of their housings.
    Pergunte ao FixBot
    Comentar
  6. Kindle Voyage Screen Replacement: passo 6, imagem 1 %32 Kindle Voyage Screen Replacement: passo 6, imagem 2 %32
    • There is quite a bit of glue between the screen and the case, So before inserting any opening tool, use plenty of heat to soften the glue.
    • Insert a plastic opening tool into the small crack between the screen and the front panel. Counter-intuitively, start away from both the fragile corners and the touch buttons in the middle of each.
    • Work your way around the screen until you can pry it all the way open.
    • There is adhesive holding the screen to the front panel, so you will need to apply a lot of heat and some pressure to completely separate the two.
    Pergunte ao FixBot
    Comentar
  7. Kindle Voyage Screen Replacement: passo 7, imagem 1 %32 Kindle Voyage Screen Replacement: passo 7, imagem 2 %32
    • Once the screen is free of the front panel, pull the loose ribbon cables through the openings in the bottom of the screen.
    • Lift the screen off of the front panel.
    Pergunte ao FixBot
    Comentar
Conclusão
11 outras pessoas executaram este guia.
Sean Yap
Membro desde: 01/22/15
1.508 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 19-12, Maness Winter 2015 Membro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membros
Autoria de 13 guias
28Comentários do guia
My screen glass is cracked, but the e-ink screen is fine. I found a replacement glass on Amazon, but how can I separate the e-ink display from the glass without destroying it? Is there a replacement piece that contains both?
John Davis - Responder Compartilhar
Did you get anywhere with this John?
dave - Responder Compartilhar
I'm wondering the same thing. How are you guys separating the screen? it's just not coming off. it's crumbing and cracking rather than lifting.
Gerald Onyango - Responder Compartilhar
My guess is that the e-ink TFT screen is bonded to the glass digitizer with a UV curing optically clear adhesive. The chance of separating the broken digi and the e-ink part without cracking the TFT are close to impossible. I know they use a very strong thin wire system to separate LCD's on small devices like phones but not sure if the e-ink screen is strong. I have managed to source a couple of recycled working screens complete with digi and e-ink together for some customers. As soon as we have them here and done the repairs, we will experiment on getting one of the damaged ones apart to see if we can replace just the digitizer. REO Technology Ltd. www.reotech.co.uk
Chris Halliwell - Responder Compartilhar
Hey folks! i feel like i found the replacement for a broken screen for kindle voyage. I am not sure about links sharing policy here, but if you will google "ED060TC1" you'll find plenty of offers from china. In order not to be screwed by amazon manufacturer uses "Montana" as brand on a front panel. Gonna order one today.
ivansaraev - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 146
Ao todo: 32,926
