Ir para o conteúdo principal
Kindle Voyage Battery Replacement
O que você precisa
  1. Kindle Voyage Battery Replacement, Back Panel: passo 1, imagem 1 %32 Kindle Voyage Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    Pergunte ao FixBot
    Comentar
  2. Kindle Voyage Battery Replacement: passo 2, imagem 1 %32
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
    Pergunte ao FixBot
    Comentar
  3. Kindle Voyage Battery Replacement: passo 3, imagem 1 %32 Kindle Voyage Battery Replacement: passo 3, imagem 2 %32 Kindle Voyage Battery Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, the back panel can slide off the device.
    Pergunte ao FixBot
    Comentar
  4. Kindle Voyage Battery Replacement: passo 4, imagem 1 %32 Kindle Voyage Battery Replacement: passo 4, imagem 2 %32
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    Pergunte ao FixBot
    Comentar
  5. Kindle Voyage Battery Replacement, Battery: passo 5, imagem 1 %32 Kindle Voyage Battery Replacement, Battery: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
39 outras pessoas executaram este guia.
Sean Yap
Membro desde: 01/22/15
1.508 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 19-12, Maness Winter 2015 Membro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membros
Autoria de 13 guias
19Comentários do guia
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Responder Compartilhar
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Responder Compartilhar
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Responder Compartilhar
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Responder Compartilhar
Still looking for a source for this battery.
Neil Hall - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 78
Últimos 30 dias: 362
Ao todo: 39,748
