Ir para o conteúdo principal
Kindle Voyage Ambient Light Sensor Replacement
O que você precisa
  1. Kindle Voyage Ambient Light Sensor Replacement, Back Panel: passo 1, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    Pergunte ao FixBot
    Comentar
  2. Kindle Voyage Ambient Light Sensor Replacement: passo 2, imagem 1 %32
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
    Pergunte ao FixBot
    Comentar
  3. Kindle Voyage Ambient Light Sensor Replacement: passo 3, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement: passo 3, imagem 2 %32 Kindle Voyage Ambient Light Sensor Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, the back panel can slide off the device.
    Pergunte ao FixBot
    Comentar
  4. Kindle Voyage Ambient Light Sensor Replacement: passo 4, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement: passo 4, imagem 2 %32
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    Pergunte ao FixBot
    Comentar
  5. Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: passo 5, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: passo 5, imagem 2 %32
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
    Pergunte ao FixBot
    Comentar
  6. Kindle Voyage Ambient Light Sensor Replacement: passo 6, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement: passo 6, imagem 2 %32 Kindle Voyage Ambient Light Sensor Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
    Pergunte ao FixBot
    Comentar
  7. Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: passo 7, imagem 1 %32 Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: passo 7, imagem 2 %32
    • Gently remove the connector to the motherboard using tweezers.
    • Continue to carefully pull the rest of the connector from the adhesive connecting it to the Voyage.
    • Detach sensor from the top using fingers
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Sean Yap
Membro desde: 01/22/15
1.508 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 19-12, Maness Winter 2015 Membro de Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membros
Autoria de 13 guias
1Comentário do guia
If i do this wiithout putting the lightsensor back on, can i then use the kindle without light ?
Best regards
Lasse
Beck - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 60
Ao todo: 3,141
