Ir para o conteúdo principal
Kindle Touch Screen Replacement
O que você precisa
    1. Kindle Touch Screen Replacement, Back Cover: passo 1, imagem 1 %32 Kindle Touch Screen Replacement, Back Cover: passo 1, imagem 2 %32 Kindle Touch Screen Replacement, Back Cover: passo 1, imagem 3 %32
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 2, imagem 1 %32 Kindle Touch Screen Replacement: passo 2, imagem 2 %32
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Battery: passo 3, imagem 1 %32 Kindle Touch Screen Replacement, Battery: passo 3, imagem 2 %32 Kindle Touch Screen Replacement, Battery: passo 3, imagem 3 %32
      • Use a Phillips #00 screwdriver to remove the five screws.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 4, imagem 1 %32 Kindle Touch Screen Replacement: passo 4, imagem 2 %32 Kindle Touch Screen Replacement: passo 4, imagem 3 %32
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Remove the 3G Board: passo 5, imagem 1 %32 Kindle Touch Screen Replacement, Remove the 3G Board: passo 5, imagem 2 %32 Kindle Touch Screen Replacement, Remove the 3G Board: passo 5, imagem 3 %32
      • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
      • Next, gently lift the 3G assembly with a Spudger or your fingers.
      • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
      • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Bezel: passo 6, imagem 1 %32 Kindle Touch Screen Replacement, Bezel: passo 6, imagem 2 %32
      • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 7, imagem 1 %32 Kindle Touch Screen Replacement: passo 7, imagem 2 %32 Kindle Touch Screen Replacement: passo 7, imagem 3 %32
      • Use the plastic opening tool to pry the bezel from the top and sides
      • The bottom of the bezel will be glued, so be careful when sliding the clips out.
      • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Rear Casing: passo 8, imagem 1 %32
      • Use your Phillips #00 srewdriver to remove the indicated screws.
      • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 9, imagem 1 %32 Kindle Touch Screen Replacement: passo 9, imagem 2 %32
      • With the screws removed, gently remove the case from the internals.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Motherboard: passo 10, imagem 1 %32 Kindle Touch Screen Replacement, Motherboard: passo 10, imagem 2 %32 Kindle Touch Screen Replacement, Motherboard: passo 10, imagem 3 %32
      • With the screen facing you, use your heated iOpener or other heating element to loosen the glue holding the WiFi unit to the screen. After 30 seconds, remove the heating element.
      • After the glue is loosened, use a thin tool, like a Spudger or small plastic opening tool, to separate the WiFi unit from the screen.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 11, imagem 1 %32 Kindle Touch Screen Replacement: passo 11, imagem 2 %32
      • With the motherboard facing you, use the pointy end of your Spudger to gently separate the two speaker's connectors.
      • This connector type requires being lifted out of place, not pulled. Accidentally pulling may damage the wires.
      • During reassembly, make sure the speaker's connectors are not pushed behind the motherboard.
      • Use your #00 Phillips Screwdriver to remove the seven 2 mm screws.
      Pergunte ao FixBot
      Comentar
    3. Kindle Touch Screen Replacement: passo 12, imagem 1 %32 Kindle Touch Screen Replacement: passo 12, imagem 2 %32 Kindle Touch Screen Replacement: passo 12, imagem 3 %32
      • Use a Spudger to separate the display's connector from the motherboard.
      • Gently remove the motherboard from the display support.
      Pergunte ao FixBot
      Comentar
    1. Kindle Touch Screen Replacement, Screen: passo 13, imagem 1 %32 Kindle Touch Screen Replacement, Screen: passo 13, imagem 2 %32 Kindle Touch Screen Replacement, Screen: passo 13, imagem 3 %32
      • Using your Metal Spudger, place the pointy end into the top of the clip.
      • Gently rotate the Spudger and lift the plastic unit to create a gap on the side.
      Pergunte ao FixBot
      Comentar
    2. Kindle Touch Screen Replacement: passo 14, imagem 1 %32 Kindle Touch Screen Replacement: passo 14, imagem 2 %32
      • Use the Spudger in the gap to pry the clip open.
      • Repeat for the other clips.
      Pergunte ao FixBot
      Comentar
    3. Kindle Touch Screen Replacement: passo 15, imagem 1 %32 Kindle Touch Screen Replacement: passo 15, imagem 2 %32 Kindle Touch Screen Replacement: passo 15, imagem 3 %32
      • With the clips separated, gently guide the Screen's Motherboard Connector through the hole.
      Pergunte ao FixBot
      Comentar
Conclusão
10 outras pessoas executaram este guia.
Adam Yerly
Membro desde: 01/20/15
2.043 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 19-5, Blackwell Winter 2015 Membro de USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Membros
Autoria de 10 guias
6Comentários do guia
I would love to know where I can get the replacement screen. Any links?
Ryan Lee - Responder Compartilhar
Good guide, thanks, finally, if you need to remove the screen itself from the black plastic frame you can do this inserting the spudger carefully between the screen and the black plastic frame and gradually moving it all round the frame. It will help if you put a heated silicon gel pack over each side before trying to release it
John Chapple - Responder Compartilhar
I have a Kindle with half of screen responding to touch
Is the touch incliduded on the screen itself? Will replacing the screen help or is there another way to fix the touch?
Mohd. Nauman Khalid - Responder Compartilhar
No, the touch circuitry is built into the motherboard.
Chris Halliwell - Responder Compartilhar
Where do you buy the screen replacement part for the Kindle Touch?
Andrew Manger - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 62
Ao todo: 11,369
