Introdução
Amazon’s Kindle Paperwhite 3rd Generation possesses a GS957661, 3G motherboard. This guide requires that the Kindle is turned off, and that a plastic opening tool, angled precision tweezers, and a PH000 screwdriver are used.
O que você precisa
Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
You want to make sure your separator goes through both sides of the bezel over top of the display.
The second photo is the layer you want your tool to pass through safely.
The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
13 outras pessoas executaram este guia.
6Comentários do guia
how do I fix my loose charging port?
how do i fix my loose charging port connection
Where can I buy a kindle paper white, new mother board?
Tip, heat the front bezel to soften the glue.
I totally know how to fix my kindle but I don’t know where to get the part. I broke the tip to the ribbon cable for the only %#*@ button on the device. do they sell those here?
