Ir para o conteúdo principal
Kindle Paperwhite 2nd Generation Screen Replacement
O que você precisa
    1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: passo 1, imagem 1 %32
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      Pergunte ao FixBot
      Comentar
    2. Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, imagem 1 %32 Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, imagem 2 %32
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      Pergunte ao FixBot
      Comentar
    3. Kindle Paperwhite 2nd Generation Screen Replacement: passo 3, imagem 1 %32
      • Carefully lift and remove the mid-frame.
      Pergunte ao FixBot
      Comentar
    4. Kindle Paperwhite 2nd Generation Screen Replacement: passo 4, imagem 1 %32
      • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Tyler Davis
Membro desde: 09/15/16
2.007 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Membros
Autoria de 31 guias
3Comentários do guia
My opening tool is orange. Will this still work for me?
FoxRunTime - Responder Compartilhar
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Responder Compartilhar
Did this work Liam?
Ben Lowdon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 171
Ao todo: 15,617
