Introdução
Disassembling a tablet often requires some gentle prying of the frame. Be sure to exercise care during these first few steps(disassembling), and do not lose your screws! The Paperwhite is a sturdy tablet that can be broken down into just a few components. This guide will show you in just eight steps how to replace a faulty motherboard.
O que você precisa
Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
3 outras pessoas executaram este guia.
