Ir para o conteúdo principal
Kindle Paperwhite 2nd Generation Battery Replacement
O que você precisa
    1. Kindle Paperwhite 2nd Generation Battery Replacement, Battery: passo 1, imagem 1 %32 Kindle Paperwhite 2nd Generation Battery Replacement, Battery: passo 1, imagem 2 %32
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      Pergunte ao FixBot
      Comentar
    2. Kindle Paperwhite 2nd Generation Battery Replacement: passo 2, imagem 1 %32 Kindle Paperwhite 2nd Generation Battery Replacement: passo 2, imagem 2 %32
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      Pergunte ao FixBot
      Comentar
    3. Kindle Paperwhite 2nd Generation Battery Replacement: passo 3, imagem 1 %32
      • Carefully remove the mid-frame from the back cover.
      Pergunte ao FixBot
      Comentar
    4. Kindle Paperwhite 2nd Generation Battery Replacement: passo 4, imagem 1 %32 Kindle Paperwhite 2nd Generation Battery Replacement: passo 4, imagem 2 %32
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      Pergunte ao FixBot
      Comentar
    5. Kindle Paperwhite 2nd Generation Battery Replacement: passo 5, imagem 1 %32
      • Carefully lift the battery and remove it from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
35 outras pessoas executaram este guia.
Tyler Davis
Membro desde: 09/15/16
2.007 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro de USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Membros
Autoria de 31 guias
7Comentários do guia
Do you have a source for the battery itself? Thank you.
mattstonecash - Responder Compartilhar
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
Adam Britt - Responder Compartilhar
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Ellis Bowser - Responder Compartilhar
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Andrej Mihelic - Responder Compartilhar
Did replacement of battery help you to resolve problem?
behemothkat - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 105
Últimos 30 dias: 507
Ao todo: 31,617
