Ir para o conteúdo principal
Kindle Fire HDX 7" Microphone Replacement
O que você precisa
  1. Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, imagem 1 %32 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, imagem 2 %32 Kindle Fire HDX 7" Microphone Replacement, Speaker Bezel: passo 1, imagem 3 %32
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Microphone Replacement: passo 2, imagem 1 %32
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Microphone Replacement, Rear Panel: passo 3, imagem 1 %32
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Microphone Replacement: passo 4, imagem 1 %32 Kindle Fire HDX 7" Microphone Replacement: passo 4, imagem 2 %32
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Microphone Replacement: passo 5, imagem 1 %32
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Microphone Replacement, Microphone: passo 7, imagem 1 %32 Kindle Fire HDX 7" Microphone Replacement, Microphone: passo 7, imagem 2 %32
    • Pry up the left speaker with the flat end of a spudger and remove.
  7. Kindle Fire HDX 7" Microphone Replacement: passo 8, imagem 1 %32 Kindle Fire HDX 7" Microphone Replacement: passo 8, imagem 2 %32
    • Pry up the right speaker with the flat end of a spudger and remove.
  8. Kindle Fire HDX 7" Microphone Replacement: passo 9, imagem 1 %32 Kindle Fire HDX 7" Microphone Replacement: passo 9, imagem 2 %32 Kindle Fire HDX 7" Microphone Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pry up the microphone connector from the rear panel with the flat end of a spudger.
    • Pull up on the microphone with a pair of tweezers to remove.
Conclusão
Blake Klein
Membro desde: 01/29/17
72.717 Reputação
Autoria de 50 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 670
